It's always a possibility that front end overload to your FM radio could occur,
but quite a slight one, given that there is 50mHz separation between them in frequency.
This should provide adequate attenuation for the broadcast unit.
I wouldn't mount it too close, try and get at least a metre between them if at all possible.
The wavelength is around 2m so any parallel metal objects in that approximate range will alter the VHF pattern. Keep them physically separated by height.
