Flying Bowline
In July's YM a reader described how to tie a "Tugboat" or Flying bowline. I can't understand the directions given. YM says Simon Jinks showed the YM team how to do it and it really only takes a couple of seconds. Can anyone explain it?
Mfc1955
26 Oct 2001
I would also like a pound for every time I tried to tie that knot!!!! I am in the same league of persons who would appreciate the easier explanation, if there is one???
SloopJohnB
20 Nov 2001
Piece of cake!
I predict you will get at least 6 different descriptions and may end up just as confused.
Anyway, here’s my attempt at explanation, being the way I do it This is for right handed people.
(I cant remember difference between “standing end” etc so I need to use my own words).
Lay rope across both open palms face up, with most of the rope to your right . Short bit across left palm.
Adjust distance between hands to be about twice size of bowline you need.
Close right hand (with fingers across rope) and twist over so that back of hand faces upwards.
Then pull rope through with right fingers and you will find you are holding a loop in your right fingers.
Thread end of rope in left hand around then into loop so that its pointing back to your left and take that end of rope back in left fingers and hold it. Pull tight on rope to your right.
Hey presto!
I can tie it in literally 4 seconds (just timed it!)
Any good?
philip_stevens
live near Saint Ives, Cornwall.
www.celticwebdesign.net
Is this a bowline on a bight, or how to tie a bowline in the time it takes to jump off a deck of a ship and land in the water.
The last explanation has left me totally "knotted", and I used to tie all sorts of knots when I was in the CG cliff team.
How about an explanation of how to tie a bowline to make a temporary lifting harness. I know how to do it, as I had to show the cliff team I was in, ........... but can anyone do it?
regards,
Philip
johmal
17 Apr 2002
OK - I am tryinig to rember
The rule is up the hole - round the tree and down the hole!
You have to make a loop to start with.
This is the break or make of the knot!
Get a length of rope.
With your left hand grab it with your palm facing up.
Grab the same length of rope further down - with your right hand - but this time palm down.
This is the clever bit - making the hole:
Move your right hand towards you left hand - so that your knuckles and thumbs are together. Grab the coil in your left hand. You have the hole!
Now it's up the hole (i.e from the floor) and round the tree and back down the hole.
Give it a good tug. If you get it wrong - the whole thing falls apart!
John M
poter
4 Feb 2002
Still going south currently in Corsica for winter
www.fairhead.com
Yes one handed, it takes a bit of practice and you have to have some pull on the running part, we used to do it for diving to tie to a buddy in murky water.
It is very easy after a time and involves holding one end while the other is looped around your body, then taking the working end in your hand and passing across to the other part with your palm up, and twisting your palm around the rope to form a loop. then taking the rope in your hand and passing it around outside the loop and pull through. Easy one bowline around your bod.
Ermmmm..... not a good explanation but it does work.
poter
philip_stevens
Yes, that is the way I was taught to do it by an old instructor when I first joined the RN.
Bowline in/on a bight will put the same bowline anywhere within a length of rope, by putting a loop in the length.
The other bowline will put two loops in the "bight" to use as an emergency lifting strop togo around the chest and under the backside.
regards,
Philip
Miker
30 Jun 2001
NW England
Yes. That's the one I know but is it a flying bowline? The trick is to have the trunk of the tree behind the hole and not growing out of the hole, if you see what I mean.
schilde
24 Mar 2002
Nope, I can't understand that either.
Anyway, what's the point of it "flying" isn't it supposed to have some advantage and be different to a normal one? I can tie an ordinary bowline in a couple of seconds the way Ken taught me (RN officer).
Also if you havn't got an end try a figure 8 knot on the bight, what's wrong with that?
Steve
BOWLINE IN A BIGHT is the correct term for the 'lifting-harness' style.
Made in the rope WITHOUT access to ends !
Take bight of rope and pass it through the hole made by the standing part, but now instead of passinbg it around the standing part and back through the hole, we actually pass the first bight OVER the loop formed in the standing part and pull back to set the knot.
Now you have two loops capable of carrying a mans weight equal size formed out of the bowline knot..... if made correctly !!!!!
Normal time to make with a 1 inch rope ..... about 10 secs
Robin2
20 Dec 2001
Malahide, Ireland
Can somebody say if this is another way to tie a bowline or is it a different knot with some extra properties? I did not see the magazine article.
I know how to tie a bowline without the need for rabbits and trees.
Robin2
20 Dec 2001
Malahide, Ireland
This is a good site. I now see that the flying bowline is what I have been using. Why does it have a special name - the end result is a normal bowline. It is so much simpler than rabbits and trees - why does the commentary mention them.
I reckon this is how the bowline was invented.
