flybridge controls on 1980 fairline 32 sedan
ipw
25 Dec 2003
lancashire boat in York
As i was mooring the flybridge port engine control lever seized, i went down and saloon cotrols were ok, as i had to go sharpish i didnt have time to look at cables etc. Has this happened to any one else
hlb
RIP
Any Pub Lancashire or Wales
Yep, think so. Side of engine Volvo?? theres a rod on the cable that gose through a hole. it sticks instead of sliding. Volsplutter did a mod I think, but I mended mine by rounding off the ends of the hole. Not surprised it sticks though.
hlb
RIP
Re: flybridge controls on 1980 fairline 32 sedan
Get some one to waggle the lever whilst you look and see where it's sticking. It's just a piece of mettle about 3mm thick.
ps1
4 Apr 2005
Wales
Fit tyraps to clips that hold outer cable to control mounting. Stiff control, a bit of pressure and clip springs off leaving inner and outer cable loose, you with lots of throttle and whatever gear you last selected. Only recourse is switch engine off fast.
