About Time
Hi all,
New to this forum. I have a Windy 37HT with 2 x KAD300. Just bought her. Now preparring myself for the winter lay up....
I have been told to disconnect the raw water supply hose from the impeller and fit another hose that can go into a bucket. This bucket I keep full of fresh water while flushing the engine. Keep the engine running for 5-10 minutes they say. Hereafter I stop the engine, empty the bucket and now fill the bucket with 10 liter of 50/50 fresh water and antifreeze coolant. Then re-start the engine and watch out when the water off the exhaust changes to the blue antifreeze color and stop the engine..... Done they say ....My concern is .... will the fresh water staying inside the hoses, heat exchanger, oil cooler etc after flushing not blend up with my antifreeze blend and cause the blend to be very 'weak'..... Should my blend actually be 30% water and 70% antifreeze in order to get the requested 50/50 in the end ?..... Never tried this before and maybe I see a problem that does not exist
Thanks for any feed back.
