Flush cutting saw
Spuddy
8 Jul 2003
Kent
I'd like to remove some mouldings for re-use and need to cut through at the base cos glued on. Sort of remember mention on here of an electrically powered wee saw that might be suitable but can't recall make....summat Germanic? T'other option is a manual one but there's quite a length to do.
Can anyone help me out please?
I think you're thinking of a Fein saw. But recently everyone has started to make them and generically they're known as 'Multi tools'.
I think Aldi might even have them in.
But you need to do some research and find a blade that will cut off the mouldings with as little colateral damage. I believe there is a very fine blade with no set available, or perhaps just the teeth set to one side.
Bosch ( & others) make vibrating multitools that can flush cut. I have a Skill version that can do what you are talking about. (I think..)
The original was Festool, very nice, but not cheap. When it ran out of patent, all the others dived in.
The kerf is probably about 1mm on the atachments I have.
If you Google Bosch Multitool..
My Skill version cost about €60, good value. has delta sanding pad as well.
Ha, slow typing again..
Also, it was Fein, as above. My wrong.
The alternative might be a Worx WX423 compact circular saw, these can be set to cut at a specific depth and will work in small areas.
I have a Bosch multi-tool as well and these make a lot of noise with a lot of vibration as they work on a oscillating movement, but depending on the job this type of tool may do the job you have.
Thanks a lot....very helpful. I'll start looking at the cheaper options
Have a look at Aldi and Lidl - they both often have them on offer. I have one - Aldi, I believe - and it has served me well for many years. Do be aware that they are not all compatible where blades are concerned - so check that there are suitable blades for whichever model choose.
I bought a Fein a couple of years back on recommendations from this forum having balked slightly at the price. One of the best buys I've ever made wrt to tools/DiY I wouldn't be without it now and use it more than any other power tool bar my drill. I second the point about checking that the blade attachment on whatever you get gives access to a wide range of blades.
The multi tools (I have a Fein) might not cut straight, because the thin blades can bend. Once the blade starts to twist or curve it can be difficult to correct. This can be caused by too much pressure, wood grain or the operator deflecting the body of the tool out of line with the face of the cut. The trick is to cut slowly and watch carefully and use a shape blade. You may have to prepare both cut surface by routing flat before refitting.
done an ebay deal for a used one. Only uncertainty now it seems is compatibility of replacement blades. Thanks for tips
Bosch multi tool. Buy good blades. They are expensive and do not last long but to the job.
Or a Japanese hand saw. Very fine cut on the pull. Frequently in the German shops as a pack of two blades and a handle. Excellent value.
Many trade outlets offer Japanese-style flush cutting saws which cut on the 'pull' stroke, with no set on the teeth. Much cheaper than Axminster Tools. Try e.g. Travis Perkins Ltd.
Saw blades on multi tools have to do a tough job, they tend to wear out quite quickly so buy the best.
