Flow jet pump Rr3426148A
scottie
14 Nov 2001
scotland
Still in box spare
Boat sold Hanse spare water pressure pump £25 plus post or collect Glasgow
R3426148A
£ 66.00 ex. VAT
Triplex 1.9' pressure-controlled pump
12 volt d.c.
Connections: for 13mm (½") bore hose or Hep20 push-fit connectors CW193
Dimensions: 230mm long, 152mm wide, 110mm high
Fuse Size: 10(amp)
Maximum Current: 3.5(amps)
Output: 7 litres/minute (1.5 gallons/minute) open flow
PRESSURE SWITCH - cuts in at 1.0bar (15psi) - cuts out at 1.7bar (25psi)
Efficient, high-flow, self-priming pump serving 2 or more outlets
Multi-diaphragm design self primes to 1.8m vertical lift, can run dry without damage
Supplied with snap-in ports for hose or Hep20 connectors
Quiet running
Motor protected by automatic thermal overload cut-out
Includes bypass feature to provide smooth, quiet flow. No need for accumulator tank
Actual Weight: 1.77 Kg (Approx. 2.27 Kg packed)
