Floppy Headlinings
Fishtigua
19 Jan 2013
Guernsey
The headlining in a 1980's Princess is falling down in the forward master. My guess is the foam has crumbled to dust.
Is it a full removal job or can you inject some glue to make a repair? Anyone done this?
Cheers
VicS
13 Jul 2002
Cheers
some people manage to support droopy head lining with battens and make a good neat job of it.
Otherwise it is a messy strip out and renew job.
Wear an appropriate ( organic vapours ) mask in addition to good ventilation when working with a solvent based adhesive in a confined space.
See Hawke House Ltd website for all materials and equipment Hawke House | Bespoke Marine Interiors
also their guide to headlining replacement Headlining Fixing Guide | Hawke House
and adhesive guide Selecting the Correct Adhesive | Hawke House
harvey38
27 May 2008
Remove the old lining material and reuse the original boards, I used this material https://www.cjmarine.co.uk/product/lining-vinyl/
No foam to crumble in years to come, it is quite heavy so a decent quality contact adhesive should be poured onto the board and a thin film spread using a spatula.
Very easy to get professional looking results but you will need two people for anything bigger than 3' wide!
Hurricane
11 Nov 2005
Sant Carles de la Ràpita
1980s Princess!!!
My Princess saloon head lining went after 15 years.
I replaced it wit the original material - not cheap.
But you might be able to get it from Lang and Potter in Plymouth.
They were the original suppliers when our Princess was built.
I bought the material and got a local guy (here in Spain) to replace it.
Boathook
5 Oct 2001
Surrey & boat in Dorset.
Cheers
Full removal job. Clear the cabin out of everything as the old foam dust goes everywhere. If possible use a vacuum cleaner with the motor unit outside to save blowing the dust around inside.
bowler
13 Oct 2014
Ireland
I recent did a couple of panels in my Fairline of similar vintage. I bought this stuff which is a match on the original. Good value and good quality stuff.
Amazon.co.uk
I choose to not use foam backed stuff. It came out really well. Stuck it down with evo stick 'sticks like s***', spread out as described above. And yes, hoover for the old foam.
[165042]
25 Nov 2016
I've repaired headlinings with contact adhesive but invariably they only last a few winters. It's not a nice job - old foam dust everywhere and you're usually upside down or looking up into it as it lands in your face. It can be done and as mentioned adding battens or a fixed feature - lamp - clock etc helps.
pvanner
13 Oct 2023
You should use a vinyl with a 4mm foam and scrim, the scrim stops glue penetrating the foam and leaving finger marks when gluing onto the boards. For glue you can use either a high temp spray adhesive like trimfix or a heavy contact adhesive like apollo a26. You can get these from a trade supplier like MBS fabrics or Kayospruce. If you all looking for someone to do it for you and i can give some names of trimmers in your area.
