xhurleyman
Sorry folks, I should have put my request on here and not on Sticky's forum.
To reiterate, I want to replace a double lined black potable water bag from my Sadler 26 with a new one of similar dimensions as in it is oblong, 865mm x 457mm x 300mm with two openings, both threaded about 50mm in diameter side by side around 200mm apart and the capacity is close on 10 gallons. I have spent a long time today researching this and only come up with three companies, Plastimo, Vetus and Lalizlas whose similar capacity tanks are square and at 700mm will not fit the space with the bag flat. Please help if you can and if anyone has had one made by a company could I have the contact details please.
Thank you
Kevin
Thank you
Kevin
