fisherman
A cautionary tale. Fv here found water ingress due to the flexible element of the internal stuffing box holder being split. A repair with rubber work gloves and jubilee clips held for not very long, the gland slipped forward, rotated with the shaft and the rubber disintegrated, they only got in due to the bilge pumps keeping pace with the inflow.
This can't be a very regular occurrence, many boats have these fitted, and I always draw attention to the fact that we are floating courtesy of the jubilee clips, but I had not come across this problem. Thinking about a work around, maybe a piece of inner tube tied back ready to pull forward over the rubber? The gland should have lugs which engage with the stern tube fitting to stop it rotating and stressing the rubber, it would need to be tied back to stop it slipping forward and rotating freely. If the stuffing box was very tight the gland would rotate within limits every ahead/astern movement.
