mick54321
New Member
Hi Iam just preping my sigma 33, and noticed that the flexible coupling was cracked, its a plastic spider arrangement. I thought about replacing it with a vetus bullflex unit for £300 including adaptor. But do i need a flexible coupling the stern gland is floating the only other bearing on the shaft is the cutlass bearing, my land based engineering says adding a flexible coupling without the correct bearing arrangement is nonsensicle, please advise. Does the engine move that much on its mounts and if so wouldnt a flexible coupling not add to this instability without adding another bearing?
