Flexible Cabin Space
Andy Ford
New Member
10 Apr 2010
I have a 21' classic cabin launch (I believe based on a Jenny Wren hull but since converted). The problem I have is the table in the cabin both occupies to much space, despite the two side leaves folding down, and it is secured firmley to the floor so it can not be moved. It sits lengthways within the cabin.
This makes the cabin sapce slightly cramped, and also means there is no flexibility in terms making a couple of adult sized berths by reorientating the table. This makes the boat, that would be a very good weekender (or longer as there are two small berths forward) essentially a day boat.
I have thought of trying to reposition it in a number of ways but have not had any brainwaves. Has anyone else had a similar problem or can you help with a suggestion or solution that has worked for you?
