Flex-o-fold propellers
Chris_Mardon
New Member
21 Oct 2014
I'm thinking of buying a Flex-o-fold 2 blade folding prop. Does anyone have any long term experience of this product who can vouch for its reliability.
Excellent product. Better material and construction than the main alternatives. On my boat (saildrive) performance same as the fixed 2 blade Volvo prop except for slight delay from stationary in reverse - common to most folders.
I've had 2 Flex-O Fold 2 bladers on my present boat, one for 8 years, the other for 2 years since re-engining. No problems at all.
Thrust ahead is very good. Opening in astern is also good, though stopping power could be better!
Four years use of a Flex-o-Fold 16"x 10" 2 blader driven by a Yanmar 2GM20 on my Hunter Channel 31. Completely satisfied. It replaced the Radice fixed 2 blader which was Hunter's standard fit. About 1/2 - 3/4 knot faster in forward and (contrary to received wisdom about folders) better crash stops and reversing. The Flex-o-Fold's blades are much wider and thicker than those of the Radice (which was a narrow-bladed sailboat prop) and seem to get a better grip on the water.
Fitted one at the beginning of the year. Very easy to fit and assemble once the old prop is off. Instructions were good. I fitted the 2 blade flexofold to replace the old fixed 3 blade. It's given me 1/2 to 1 knot sailing speed increase. Under power it pushes the boat to cruising speeds at much lower engine rpm (2300 instead of 2800rpm). I've not noticed much difference if any when berthing in the marina, astern is the same as it always was with the fixed 3 blade. Overall, very pleased with the purchase.
Sounds good at what speed do you get the 1 knot speed increase. What sort of boat is it.
I think you have it wrong about "recieved wisdom" re crash stops and reversing - ALL folders have a justifiably poor record in this department. Radice, as one of the cheapest folders on the market has a number of known performance and longevity issues.
On a more positive note - having been a customer of the manufacturers for 24 years, though not for the Flex-o-Fold, - I can vouch for their after sales service and general support.
I think you have it wrong about "recieved wisdom" re crash stops and reversing - ALL folders have a justifiably poor record in this department. Radice, as one of the cheapest folders on the market has a number of known performance and longevity issues...
The Radice prop I replaced was a fixed one not a folder
...It replaced the Radice fixed 2 blader ...
The received wisdom (i.e. the normally quoted opinion) is as you say that ALL folders are poor in this regard. I am saying that the Flex-o-Fold is better than at least one type of fixed blade prop. I have not got it wrong. I am speaking from personal experience of a direct comparison with no other variables involved.
