Flex Coupling With Flex Engie Mounts And Flex Stuffing Box
sg2012
New Member
10 Nov 2012
Hi,
I have sailboat with volvo d2-40 fitted with the original flex engine mounts, and flex stuffing box (buck algonquin packing connected with rubber hose). I am thinking of adding R&D flex coupling, primary to act as a drive saver (it suppose to be relatively stiff). In the volvo Installation manual it says: "When using a flexible shaft seal and flexible engine
suspension, a flexible shaft coupling must not be fitted". reading around it seems this Installation is common, but still no conclusive answer.
Ill appreciate your advice please.
Sg
I fitted a R&D flexible shaft coupling last winter to see if it would reduce resonance at certain revs. It did and the whole rev range is now much smoother. I have yanmar 2gm20 sitting on flexible mounts with a traditional stuffing box with rubber hose to stern tube and a P bracket.
I think the stuffing box has nothing to do with it as it provides no support to the set up.
Volvo information doesn't cover all installations. We have flexible engine mounts + flexible stern gland but, what's not evident until everything is uncoupled is that we have a bearing in the front end of the stern tube, in addition to the cutless on the P bracket so, the shaft isn't free to move with the engine. We have R & D flex coupling.
The basic rule of thumb is that of the three elements between mounts coupling stern gland one must be solid to avoid the whole lot dancing about .
However R&D I believe that their couplings are rigid enough to hold the system together .
A quick call to R&D would confirm this .
Thank you for your replies,
I think I have the same setup as Spyro
I heard about the rule of the tumb -> too much freedom will let the engine and the system dance too much. I am hopping the R&D will be stiff enough. I sent them an email few days ago and still waiting for a reply (maybe still in vacation). I will update with their answer and with the result (my boat is currently out of the water).
here is the answer from R&D:
"The problem is it is possible to get the coupling to run excentrically if it is not registered side to side like some products.
Our coupling has a male register one side and a female the other so that it maintains it concentricity to the axis of both shafts therefore you can use our coupling."
so we are good
thanks everyone!
Well, that says it all. :rolleyes:
Couplings
I can't figure out if VicMallows is being sarcastic or if he means it.
I certainly can't figure out the quote from R&D. The word "registered" has me confused. Does that mean restrained as in some movement permitted but not much or does it mean held with no movement allowed.
How does a male register and a female register work? someone please explain olewill
A spigot- male on one, female on t'other half coupling.
