My old but excellent Plastimos are fixed focus. They seem to work at all useful ranges and to suit all my crew members - even my steward is impressed. So what is the downside of fixed focus?
They are not great for bird-watching (not the topless-next-door variety) I don't think it's a consequence of old age creeping on, but I find that fixed focus bins cannot cope with going from very close range, a few metres, to infinity. I use variable focus on shore, fixed focus at sea, although I also have a variable focus pair on board (for topless use) /forums/images/graemlins/smile.gif
Top quality veriable focus will give a slightly sharper image but at the cheaper end spend the money on the lenses not the focusing mech' I have plasimo fixed set at £50 and posh variables at £350, they are better but would not have got the if they hadn't been at 75% dicount fron LIDL!
The downside is I don't understand how they work. I have a pair and they work very well but still think there must be some sort of black magic at work. I don't like not knowing how things work...
You'll get to find out why bins need to focus when you approach the three score and ten! The only ways to increase depth of field are to reduce magnification or aperture - there's no free lunch in optics!
Fixed-focus (a misnomer as they'll have individual eyepiece adjustment) binoculars obtain their depth of focus by a much reduced aperture.
This means that light-gathering is, of necessity, reduced and they can be less effective in low-light conditions.
However, you'll not find genuinely waterproof binoculars with central focus.
Light-transmission is probably more influenced by quality of optics than by size of aperture. Porro-prism binoculars tend to give better results than roof-prism binoculars of similar quality.
Another criterion of quality is whether or not their mil-spec - which are always heavier than their "ordinary" brethren because of die-cast construction.
In fact ABS moulding can be even more precise than diecasting and far less fragile.
Final price determinant is whether or not they're assembled in China.
The Plastimo binoculars (IMHO) are definitely in one of the lower quartiles in optical and construction terms.
If you're looking for a price/quality benchmark have a look at the ABS, Chinese-assembled Fujinon Mariner range.
Apologies for coming in a bit late to this post but there are a few errors in the replies.
Fixed focus works by setting the focus to the hyperfocal distance which is when a lens is focused at a given distance and the depth behind the focused point becomes infinite.
The depth of focus also allows closer objects to be acceptably sharp. The aperture is NOT reduced - a 7x50 fixed focus bino is as bright as one with either individual focusing eyepieces or centre focus. Individual eyepieces are not called fixed focus and fully water proof binos can and do have centre focus and usually an ability to adjust the right eye focus to suit those of us whose eyes are not the same prescription.
A down side of fixed focus is if you don't have the same eyesight - left and right - so have to wear spectacles to see clearly with both eyes. Also if you are short sighted, the whole range of focus will be shortened. Vive versa if long sighted.
Fixed focus are a compromise. They cannot give a really sharp image across the whole focus range but they are much quicker to use.
Porro prism models have an advantage over cheap roof prism models with regard to image quality until you pay enough to get phase corrected roof prisms which are then no different from porro. If you want to know the technical reason, pm me.
