manus
New Member
I recently bought a boat which has a volvo penta B20 engine, the problem is I dont know which one. It has a 100 series outdrive (ancient I know). The engine has twin carbs which makes me think its a AQ130.
The problem is the exhaust manifold is leaking coolant into the exhaust through a couple of pin prick size holes. I ran the boat and the engine is purring like a pussycat, however I'm thinking if the manifold has rotted then chances are there is also damage to the engine.
Here is what i'm thinking.
1. Replace the manifold (£120 2nd hand) and take the remainder of the season out of it.
2. Over the winter, replace the engine with something more up to date and this is where my question comes in.
Q1. Being a competent mechanic but novice to boating, is is worth my while replacing the engine alone or should I also replace the outdrive?
Q2. Any suggestions on replacement engine/outdrive units?
Q3. Should I strip and rebuild the Volvo engine?
Q4. Where can I get parts for the engine?
As ever, I wouldnt mind a bit more poke out of the engine, it allegedly puts out 130hp but then again the boat is allegedly 1985...
Thoughts, comments, general banter all welcome
