mickshep
Some time ago I bought the above to fit to Wraith. The cable is installed into the masthead unit from new. at the other end is fitted a bonded on plug approx 19mm dia'. The supplied instructions just tell me to fit the masthead unit and feed the cable to the display unit. My concern is that whilst drilling a 19mm hole in the flat plate at the mast head to take the plug is not a problem, doing the same in the side wall at the base of the mast may weaken the mast, /forums/images/graemlins/blush.gif. Has anyone cut the cable at the display end and then re-joined it or is this asking for trouble? Cheers all, Mike.
