superheat6k
I have bought some Forespar Marelon seacocks for my raw water inlets. ASAP supplied them complete with a mushroom through hull, but there is no retaining nut for the through hull.
The valves have three mounted holes 120 degree spaced around the periphery with a flat face as well as the 1 1/4" BSPF screw thread..
What way would others fit these (I will seal with sikaflex) ...
1 Adjust the length of the through hull to suit the hull thickness with say 1.5 - 2 turns shy of the bottom of the seacock female thread, then simply wind up damn tight direct to the hull.
2 As 1 but with a marine ply spacer plate say ~ 100mm diameter (valve size is 1 1/4" bore, so OD ~ 65mm ?
3 As 1 but also through bolted through the peripheral holes ?
4 As 2 but also through bolted ?
Thanks all
Thanks all
