Bosun Higgs
N/A
My boat has an unusual arrangement for a modern boat - no P bracket but instead a log ( ie a small fin) through which runs a grp stern tube. .
The end of the stern tube sticks out of the log and takes a water lubricated bearing. OK - not to the issue. The boat has a heavy old lump of a Radice folding prop. The GRP stern tube is thick walled so the bearing itself is fairly thin ( 25mm I/D and 1 3/8 OD by 100 mm long) walled. And its all not helped by the final inch or two of the stern tube not being quite circular bore. And the weight of the prop makes the life of this bearing fairly short.
So could I help myself by fitting not one but two water lubed bearings - after all, the stern tube could easily take half a dozen end to end.? Or would I be giving myself difficulties as the engine moves a little on its mounts etc.
