Matt341
Hi All,
We have a 28 foot Mirage and recently have been looking at upgrading to something more comfortable for staying onboard. Came close to buying a Konsort but after reading the recent survey and comparing with others we felt she was overpriced and needed some expensive work doing.
So have decided to stick with the Mirage and to do some improvements.
A while back I did a post about everything that would need doing to make her comfortable for staying on and now that the shorepower has been professionaly sorted, fridge fitted and new upholstery I feel ready to tackle the water system.
There is a large water tank at the bow of the boat which is in good condition and I dont really want to change it, there are then 2 pipes coming from it, one feeding the heads sink, the other to the galley sink.
If at all possible I would like to keep this system as it is so when on anchor we can still use it to save on battery use.
I have a rough idea of what should be fitted -
pipe from tank straight to water pump, 3 way split, 1 to mixer tap in heads, 1 to galley tap and the other to calorifier? 2 Hot water pipes then come from calorifier, 1 to galley and 1 to heads?
I do have a few questions though, what pump should be fitted? I would rather go for pressure system as opposed microswitch, can I buy a Whale submersible water pump to put into water tank and then fit pressure switch to control pump or should it be something like the Shurflo Trail King?
I have been given mixed advice, some people say I should have a pump for cold water system and pump for hot water system, on the motorhome we only have 1 pump for both hot and cold but maybe a yacht system is different?
I also dont want to spend a fortune on the job.
Also what is the best Calorifier to use? The engine is a 2006 Yanmar 2GM20, how simple is it to connect the calorifier to it.
I look forward to your advice.
Many Thanks
Ian
Many Thanks
Ian
