Laundryman
My Oceanis 321 came with only one coachroof winch. On the port side there is a moulding in the roof showing I presume the position of the port winch if fitted. The stbd winch doesn't appear to have any kind of backing plate as far as I can see. The bolts come through the grp and are secured with nuts. Is it likely to be embedded in the grp and if so, is there likely to be one embedded on the port side. If there is, will it be pre drilled with the bolt holes and/or threaded and how will I know where the holes are? Ive made myself a backing plate to fit underside the roof so in a way I am hoping that its just a thick layer of grp. I don't see how I can find the bolt holes in an embedded plate without drilling loads of small holes. Advice please Thanks Alan
