Fitting a BNC connector
ShipsWoofy
10 Sep 2004
<u>Fitting a BNC connector.</u>
It is always difficult to post definitive ‘how to’ posts to the forum, someone always picks faults with your method. But I will take the plunge and hopefully someone will find this post useful.
As it happens I actually had the wrong sized BNC connector for the coax I was using on the day, the backing screw on the connectors come in different cable sizes, this means in this case I had to ‘whittle’ the coax insulation a little to allow the backing screw to slide over it. Had I had the larger size in my toolbox this would be unnecessary. For the purpose of this exercise it is not important; the following instructions will not refer to this problem again.
1. What’s in the bag?
A 50ohm BNC clamp plug from Maplin, Link to maplin
If your application is navtex then you will probably require the 75ohm connector, check in the manual.
Laid out in order of fitting, check you have all these components.
Backing screw – washer – spacer – ferrule – pin – front connector assy
(These are my descriptions, they may have official names)
2. Fitting the connector.
The first job is to strip back the outer insulation on the coax. About the length of the assembled connector will do, trimming can be done later. I use a surgical scalpel, try not to cut too deep as you will damage the braid, the insulation is soft, just work it round in your fingers while you apply gentle pressure on the scalpel. Once you are through you can pull off the insulation leaving it as above.
Slide the backing screw over the braid and onto the cable, roll back the braid to expose the inner. Now, slide over the inner, the washer, spacer and ferule. Strip back the inner with the scalpel so it is just proud of the ferule, see below.
Snip the inner so that it fits snug into the pin bucket, the wire should reach the end of the pin, but when fitted the pin should be touching the insulation, no inner wire should be exposed between the pin and insulator.
3. Soldering
Sorry about the focus
We need to tin the inner, you will find the insulation will melt easily, so practice tinning wire on scraps you have around before doing this. The reason for leaving the inner insulation just proud is to allow for a small amount of shrink. When you become proficient at soldering you should be able to reduce this shrink considerably.
Now we need to add solder to the pin. Turn the pin upside down to expose the bucket, here I have stabbed it into the bottom of a tissue box to hold it while I work. Hold the iron against the bucket and allow time to heat up, when the bucket reaches a the right temperature the solder will flow, you do not put solder to the soldering iron tip, you apply it to the bucket.
Once you have solder in the bucket, hold the iron against the bucket and wait until the solder melts. Upon melting, bring in the coax and slide it in, remove the iron and allow to cool. Do not be tempted to dip in water or a wet sponge as this will weaken the joint, gentle blowing on the joint is fine.
Reassemble the components as above.
Trim the braid, but not so much that it is flush, you want to trap braid within the threads when you screw the connector front to the backing screw. Here I could have probably allowed a little more length of braid to be exposed. Important – Check for stray braid, a single wire from the braid to the pin can short your connection and damage equipment. Measure across the pin to braid with a multimeter on resistance, a dead short may indicate a problem, even with an RF antenna connected you should get a few ohms not a dead short i.e. 0 ohms.
Assemble the plug and tighten. Important – hold the back screw still with the spanner and screw on the front part, screwing the back screw at this point will tear the braid.
The finished job.
Hope it helps......
Good writeup - worth turning into a PDF and asking Keith if it can be stashed somewhere useful on the YBW servers. Mike (Hurricane)'s PDF on braid-on-braid splicing could go in the same place.
Rick
You forgot to say that when you get to the end you then realise that you forgot to pass the wire through a grommet. You then need to cut the wire, put it through the grommet and go through the whole procedure again! I've done it so many times. /forums/images/graemlins/mad.gif
I see you use a gas soldering iron. How do you get on with them? I find they never seem to last very long and I wonder if I have been doing something wrong to mess up the catalyst. I've had three of the things and have now given up and use a 12volt electric iron.
Lovely; beatifully described and great pics. Well done.
I'm a lazy old poo and have discovered that CPC ( http://cpc.farnell.com/jsp/endecaSearch/...;Ntk=gensearch) sell solderless BNC connectors, both "plug" and "socket" varieties. The inner solid conductor is held by an internal spring clip with a barb. The connector can be re-used as well.
Perhaps not as "pure" as the solder variety, but works well for me.
Brilliant post must have taken a lot of time and thought,just the sort of thing we numpties need for dealing with electrical bits.
I love the posts where people say just buy components x,y,z from maplin solder to PCB and insert in line.
I still read the idiots guide attached to 13amp plugs as i'm of the school that thinks if you unplug an appliance without switching it off at the socket the leccy will leak over the carpet.
Next one? Remaking a radar lead so that you can get cable through deck gland,I'm sure its simple but I have always had to GALMI to do it.
I use a network crimper ... that has a set stripping section ... the inner cable then buts up into the centre pin nicely to make contact. The inner braid is held by the insulation while the back of the plug winds itself between insulation and braid.
Crimp and your done.
Never had trouble with them - I'm sure somebody is going to now tell me it's all wrong.
Gas Irons are great IMHO. Far faster than electric but they do eat tips if you are not careful. Have to keep an eye on the adjustment, it is very tempting to wham it up full all the time but this will kill the tips pretty quick.
I have a bunch of tips for different jobs, the tip as above needed replacing recently so I bought half a dozen. I now have a decent flat tip which would have been better for the job. I also have a mini gas torch tip which is great for heat-shrink, not tried brazing yet. The rope cutter is fab!
This is not the cheapest iron, nor the most expensive. Looking at them, the cheapies really are just that, maybe that was part of your problem?
I am so used to using it now, when I use my plug-in iron the cable gets on my nerves.
I agree that the gas irons are great (when they work!), which is why I am interested in your experiences. I also liked the "knife" tips which, as you say, were superb for cutting synthetic ropes. The idea of something which is truly portable and could even be used at the top of a mast also appeals.
It's just that they really don't seem to last long with me; twice they have packed up after no more than 3 or 4 uses. FWIW one of them looks exactly like the one in your pictures (which are very good by the way!). One was a cheapy and the other...I can't remember what I paid for it.
Re: Fitting a BNC connector - Addendum
I have realised that my posting shows an incorrect way to fit the plug.
If I had been using narrower coax, to match the plug then the back screw, washer, spacer and ferrule (grommet) would have slid over the cable. In that case the method is the same but the braid would be splayed out over the grommet and back to the threads. It would mean a much shorter trim of the inner.
When I get a chance I will do it properly with the correct sized cable.
Some people do not allow the braid to go back to the screw, either or, I would say between wiremen and electronics types it is about 50-50, jury's out type of thing. By adding the braid to the connector it does lock the connector onto the cable, how many of us have found spinning connectors. Those that spin will quickly break the inner (signal) wire.
Sorry, will put right ASAP.
Where's me camera!
I am one of the latter who don't allow the braid into the thread. If the correct grommet is used, it grips the cable fairly tightly and I haven't had one spin yet...
I used to put them on for a living when I was at the Royal Radar Establishment - golly that was a long time ago! Its gone through several name changes since then.
I seem to have fitted many BNC also. Some types we used did not have the washer but rather a different shaped rubber seal against a shaped ferule. Otherwise the same procedure. if you are connecting to old wire you need to tin the centre wire but make sure it will still go into the pin.
However on new wire I did not tin the centre wire. The pins we used had a hole in the side. Assuming you are using new wire apply the iron to the side away from the hole and feed in very thin solder into the pin hole onto the centre wire. The iron needs to be quite clean so it doesn't leave a dag of solder on the pin. Any build up will not fit into the connector.
If you are trying to use a second hand conector you have to hold the pin and heat it till the solder melts then feed the centre conductor in. It is quite tricky. It is usefull to have a tiny drill bit to drill out the sollder. Again you need a clean iron. Any build up of solder needs to be filed off which really strains the centre conductor.
I vividly remember (after 30 years) late at night holding a pin with a pair of cutters while upside down under an aircraft panel while trying to fit a used pin. It was a more specialised but similar connector (a TNC I think) when something went wrong with my balance and I chopped the pin in half.
Most professionals now use a crimped BNC but solder is still common.
Finally the correct location of the pin pin is deep enough so that it can be just felt with a finger nail. ie flush with the inner body of the connector. (not the moving part) sometimes on old wiires the centre will shrink and the pin retracts too far. it is a good habit to check this on BNCs if you are having problems. olewill
Thank you very much Dogwatch for the detailed info. I'm going to print this all off and try and fit my nice shiny new DSC radio over the next couple of days
I seem to remember you helping me with a post about a year ago when I had to replace a BNC conector. A lad at Maplin gave me a quick lesson in fitting the crimped on type..of course I had to buy a decent crimper, but it made the job very easy, and it still seems to be doing the trick.
Hiya Dogwatch
Please may I politely correct a fundamental error in your wonderful pictorial representation as to how to solder a BNC connector.
The outer braid HAS to pass inside the backing screw and then INSIDE the washer spacer (compressing grommet) and finally INSIDE the chamfered ferrule.
You will notice that the washer and ferrule in your pictures are quite sloppy on the inner dielectric. This extra diameter is to allow for the outer braid to also pass though to maintain the correct impedance before folding back.
The braid then doubles back over the ferrule and is finely trimmed. This is where the outer braid is trapped to form the correct bonding with the plug. This is why it is of a chamfered shape. As you correctly state, none of the outer braid must contact with the inner conductor!!
This leaves the washer to do its job of allowing the backing nut to tighten correctly without damage or distortion to the braid and/or dielectric.
Much more importantly, it allows the compressing grommet to sit on the outer of the coax cable (white in your photographs) which will form a water tight seal to stop any future ingress of moisture into the outer part of the coax as this is a major cause of cable breakdown.
An interesting aside is how the name "BNC" came into existence.
During the Second World War (I believe) the American government tasked the three American armed forces to 'come up with 'a decent battlefield RF connector'.
The task was finally 'won' by the Navy (of course) and the connector was officially called the 'Navy Connector'.
This name, in time was shortened to the 'N'-connector by which is now known and loved by RF engineers world wide.
From this 'N'-connector type was spawned the "Bayoneted 'N'-connector" (BNC) and the more robust "Threaded 'N'-connector (TNC).
If you look closely, you will notice that the centres of all these connectors have a standard 'size' if you look end on into the plug.
This is to keep the impedance of the cable to either 50 ohms or 75ohms.
More interestingly and far less well known is that a 50ohm male 'N'-connector will mate exactly into a female BNC with out any mismatch (or damage to either plug)! The same with a TNC to 'N'-connector.
I hope this is of interest and helps?
moi auci, jools all you have to do is ask your mukka and i will produce the tools! i have a BNC tool and somewhere the crimp BNC ends, used to do networking with them but it all CAT stuff nowadays.
Stu
