Fischer panda ms4500 FCB 3.8kw
mainshiptom
15 Jul 2002
Faversham kent uk
Panel is showing running hours but panel will not come on for start,
Worked last night after fiddling around I thought it might be a bit hot from main engine?
But all is cool now and refusing to switch power on
any ideas?
On my panda (8000 series) there is a very small fuse (0.5 amp) on the back of the panel that blows occasionally which if I remember would have the same symptoms as yours.
After fuse checking
Is there still an “off “ off .?
Or it’s bats dead .Hows it’s powered up to start it ?
House ? Or if dedicated - loose lead / dead it’s seeing no volts .
No fuse on back of control panel, one fuse on genartor of 25 amp for the stater
I am suspecting the relays might need to giggle them?
When I had something similar on my Mase 5.0 it was corrosion on the terminals. Once removed all was good in the world again. I had the same symptoms in I would get hours showing, but not even a click when I tried to start it.
If the generator has it's own battery then bear in mind smaller Fischer Panda units have no built-in means of charging the battery used to start it. I have a separate battery charger just for the generator battery that I have to remember to switch on when I use it. Just running the generator will drain the battery if you don't have a dedicated battery charger to keep it topped up.
If your unit uses the engine or domestic batteries then just ignore everything I've just said :)
+1
destroyed a brand new 100Ah battery this way.
Although it wasn't in a day...
V.
Sorted , spend some time taking all realy s and cleaning contacts and replacing .
The genartor is new but not been used for a while....
Thanks for all the help and suggestions
