stuartwineberg
Happy New Year to all. This is my first post and thanks to all the regulars whose advice has helped me in many areas.
I have a newly acquired 2005 Hardy 36 with the above raw water cooled genset which has only 16 hours on it (after nearly three years, so well underused by previous owner). The problem started with the genset cutting out with engine overheat after 5 mins. FP advised me to remove the thermostat and blank off the bypass pipe between the sacrificial block and the exhaust. Genset now runs for 5 mins but cuts off with an exhaust overheat. Just replaced the impeller. Old one had one vane gone which I could not find.
Quirk is that used water is coming not out of the exhaust but out of what appears to be the air vent pipe at the top of the siphon loop.
Do I have an airlock somewhere or a more serious blockage. As usual access is almost impossible.
Stuart
Stuart
