David_Jersey
I have used fibreglass resin and cloth (?!) before to repair stuff, but for nothing major or that gave a tidy result (no MOT's here /forums/images/graemlins/shocked.gif /forums/images/graemlins/smirk.gif).
I have read the articles in the mags and it seems to me that Epoxy is pretty much the same idea, except it is "better" and also that you can add stuff to the Epoxy resin so that it can act as more of a Filler than Fibreglass Resin can and then sand it down more easily than FG Resin.
What I was thinking of doing is using it in a non structural way to coat bare fibreglass for cosmetic reasons only. (the forepeak on my boat is the Head and loads of storage, but does not have any Gelcoat on the inside of the hull - at present it has been painted and to be honest looks absolutely fine............but I think it would look better with a smooth finish.
My initial plan is:
a) Clean off any flaky paint / abrade the existing fibreglass (wire brush / a wire brush on an electric drill), but this will not remove every last flake of paint - in fact because of the nature of bare Fibreglass I suspect that there is no way to remove 100% - any views on whether the Epoxy will stick enough to this sort of surface?
b) Remove as many fittings as possible and mask up any that are left.
c) mix up some Epoxy Resin to a formula that means that when cured it can be sanded smooth by electric sander and by hand, but thick enough to cover up the raw fibreglass and no doubt a few imperfections / dings - would I need to add cloth? or would it be thick enough on it's own, even if it takes a couple of coats?. (I can't remember what you add to the Epoxy? and is the result that "user freindly" in practice to sand down?)
d) paint it by hand, however many coats it takes to get a coat that looks right!
I would like the end result to look like it was moulded / the original Gelcoat.......indeed like the outside of the hull would be nice. Of course I have a tendency towards aiming high (wishful thinking??!).
I appreciate that this would be a lot of hard work for very little result (in technical terms called "a pig of a job" /forums/images/graemlins/grin.gif), but it is an excuse to "dissapear from the world" and it is the sort of project that suits me as someone with more OCD than skill - I.e. I will keep plugging away until I get the right result!
BTW I do have something to practice on at home and that if it turned out to be a disaster / I am more useless than I think - it would not end up being on view (the wash basin "cabinet" unbolts from the bulkhead and the inside could do with a repaint - no reason why I can't use it as a test piece).
Any thoughts?
My initial plan is:
Any thoughts?
