First question for FAQ - What sealant to re-bed my keels?
misterg
31 Oct 2003
N. Wales
No, I really do want the answer!
I need to re-bed the keels on Pippin this winter - water pumped out of the keel/hull joint when giving the keels a good waggle while the boat was on the hoist at lift-out.
I've searched the forums, and although I haven't found a clear recommendation, 3M's 5200 crops up in discussion (polyurethane?). I've removed a few of the keel bolts, and the existing sealant (around the bolts, at least) is some sort of poly-sulphide.
The boat is a 22' bilge keeler, and I intend to do one side at a time by chocking the keel up, slackening the bolts and rocking the hull onto the other keel with supports at bow & stern. As soon as I've got room to work, I intend to clean off whatever is there, slap some goop on, and lower the hull back onto the keel.
Question is: "What goop ?"
(Keels are cast iron with a flange on top that fits into a recess moulded into the hull, and are fastened on with stainless steel bolts).
Andy
Do you recall how long ago? I can't find anything in the "features" index of the PBO site.
What is the "Wurth" sealant?
Ta.
Andy
Arbosil do a non setting sealant (Arbosil 1096) that is used for bedding in windows, joints on water tanks etc. Sticks like s##t and seems to do the job. About £7 for a large tube
Thanks! (I'd only gone back to the beginning of this year, and the article doesn't show up if you just use "keel" as a keyword).
Having dug the issue out, it just quotes "Sikaflex". More worryingly, it took them 20 minutes hammering wedges into the hull/keel joint to get it to part /forums/images/graemlins/crazy.gif
Is this the Wurth adhesive sealer you are referring to ? (small .pdf file)
Thanks.
Andy
