Shakey
Have noticed that a previous post with regards to first aid and CPR has attracted many views and comments, I thought I'd post the current 'official' procedures for dealing with a casualty.
Before you read this, the usual legal disclaimers apply. This is for informational purposes only. You really should undertake a first aid course, I'm only describing the order of the procedures to remind those already proficient, not how to do the procedures. The protocols for CPR changed again a couple of years back, this is the current version. I hate the fact I have to cover my back when offering information that might save a life, but that's life nowadays. It's not my fault if this doesn't work.
The following is taken from a handbook approved by the Health and Safety Executive revised May 2004.
If the casualty is not breathing or is only making occasional gasps or weak attempts at breathing ASSESS THE CAUSE then follow the basic life support action plan:
ALCOHOL / DRUGS / DROWNING / INFANT / CHILD / CHOKING / TRAUMA.
Give two rescue breaths
Check for signs of circulation (eg. movement, coughing, twitching)
If signs of circulation present continue artificial ventilation (AV). After one minute go for help. Upon return recheck airway and continue AV checking for circulation every minute. If circulation has stopped commence CPR.
If signs of circulation not present commence Artificial Ventilation and External Chest Compressions (aka CPR) for ONE MINUTE. Then go for help. Upon return re-check airway and continue CPR until help arrives.
IF YOU SUSPECT HEART FAILURE
*** GO FOR HELP ***
Upon return, recheck airway, give two rescue breaths, check for signs of circulation.
If circulation present continue AV and check circulation every minute.
If no circulation commence CPR until signs of life or help arrives.
All this looks a lot better and easier to understand when depicted in a flow chart, if you're serious about first aid then you need to read an up to date book on the subject. Note that first aiders aren't supposed to try to find the pulse anymore!
Hope you can remember this but never have to use it.
*** GO FOR HELP ***
