MapisM
Yup, all agreed.The main differences between fins at anchor and underway are (i) fin area (bigger is better, at anchor), (ii) hydraulic power (you need higher fin speed at anchor) and (iii) the algorithms (when in "at anchor" mode the systems switch to entirely different algorithms becuase the fins have to "swim" to stabilise the boat whereas underway they act as foils, and these are quite different things)
But re.the algorithms, my reasoning behind the idea of trying them also at rest was based on the fact that they're actually unaware of the boat speed.
The only input to the system is the gyroscope, which senses the roll (and its speed).
Therefore, my guess was that the system would have moved the fins as widely and as fast as possible, as long as the roll doesn't stop.
And this is what seems to happen. In fact, also the panel gauges show that the fins frequently reach their max angle while operating at rest, whilst this very rarely happens while cruising.
So, I'm not sure that a smarter control system alone could significantly improve the zero speed performance, unless using also larger fins and faster cylinders.
Considering also the pump complications you mention (which I agree with and I didn't think of in my previous post), I suppose that for stabilization at rest I will stick to the proven method I've used so far: looking for quiet anchorages!
