TimH
I'm always keen to keep the fuel tank filled up, especially when we come into winter. Before filling up I spray water over the teak deck near to filler cap. This stops diesel soaking into the teak, if there is bubbling up of diesel from the filler pipe or overflow from the breather pipe.
Two things drive me bats. First the breather pipe is in the cockpit. This is bad design, as over flow of diesel ends up in the cockpit. Second it is impossible to fill the tank without spilling diesel. If you hear the gurgling suggesting you are near to having the tank full, all is lost. However fast you put the cap on, fuel will flow out of the breather. Inevitably this spill ends up in the sea which I hate seeing.
Has anyone got any tips? I've been thinking of a piece of cork on some coat hanger wire with a flag on the end but think this could end in diaster as the blessed thing slips down into the tank!!!!! I'm also not obsessional enough to keep records of engine hours,RPM and plots of potential fuel useage.
PS On the newer version of the boat the breather is on the outside of the boat. Helps with one problem but doesn't stop the pollution.
