ithet
My twin keels are well bedded onto the original two part sealant. But there is a gap around the top edge and also some areas where the epoxied hull is slightly proud of the keel flange. In the past I have used Sika, but it is hard to get a smooth finish, and it falls off after a season anyway.
I am looking for suggestions for a different flexible filler or sealant, preferrably one that is sandable or easy to get a smooth finish where it is used to fair in a wider area. It has to be able to adhere to primer and fill some areas to a depth of a few mm. It only needs to perform moderate sealing duties and no mechanical bonding as the original sealant bedding the keels down is fine.
Thanks in advance.
Thanks in advance.
