Matata
I want to repair an area where a wooden ply horizontal platform meets the ascending side of the hull. The length is approx 2 meter long , up to 2cm deep and 2cm wide . Its like an irregular trough/channel. To fillet it in, after good preparation, i was going to make up a filled solution of epoxy and fine milled glass fibres so that it was like heavy mayonnaise /light peanut butter consistency and put it in with a cake makers piping bag. Then trowel / smooth over it. Once it was starting to go off but not set I was going to put a wide bandage of glass over it, say 5cm either side of the trench....now my question! Is mild glass fibre easy to work with? will it blend into a flowable consistency? Where can I get them. What size fibres would you recommend> Ta nik
