catmandoo
Recently posted problem regarding above . Have now drained tank and found that all contamination lying as goo on bottom of tank close to draw off and sump apart from loose flakes like muesli lying loose. These invade draw off pipe 2 inches above sump bottom when boat in "disturbed" condition and cause intermittant interruption of flow to engine giveing reduction of revs etc . Interestingly tank bottom at slight slope to sump so water settling out on bottom flows to sump which explains location of sludge in same area
Used Pela oil extractor to draw of sludge from tank sump first ( no bottom drain) before pumping out diesel through hand hole via Amazon pump . Then wiped remainder of sludge off bottom close to sump using Pampers . Only took 10 minutes . No contamination else where . Let diesel settle in 30 litre containers and then poured back into tank via funnel with gauze mesh trapping any particles. Diesel slightly coloured and not virgin light straw colour so added double dose + of Soltron . (By the way DOM - S would travel better in whisky miniatures if it had a peaty colour instead of clear . Gin miniatures not so available up here ". Will now wait a month or so and report back . Am expecting to see clear virgin P*** colour . Hope it works
