My Friend Recently Started Having problems with his feathering 3 blade prop in reverse, it works perfectly fine in ahead but when put in reverse it seems to overload the engine with little affect!
its not the engine even once warmed to a decent temp it still plays up but only in reverse not in ahead! Which makes me feel the prop is fouled in away where in reverse the prop cant open properly
if its a Kiwiprop in a muddy water area, its likely that the reverse mech is jammed by fouling on the bearing plates. You need to disassemble it, clean it thoroughly, reassemble with LOADS of grease, and then anti foul the outside with something like trilux.
Mine does this 2/3 of the way through the season on the River Crouch. Harumph.
It does help if reverse is engaged and used frequently. Mine isnt as I live on a swingging mooring, so dont need reverse normally.
ok thanks will check that out am gonna check the gearbox aswell as it might be something in there havent seen it yet got a call from my friend this morning so will just eliminate all options whilst still in the water then get it lifted and carry on then thank you
The pitch is much coarser in reverse on Kiwi props which is great as long as your gearbox has a higher ratio in reverse. Also it helps to set the tick over speed a bit higher, and use some throttle in reverse! It could well be as FullCircle says that the reverse spring mechanism is not fully setting the reverse pitch due to internal or external fouling. Also the prop has several grease points which need attention with a powerful grease gun with a fine nozzle, obtaiable from the UK Kiwi suppliers.
Is a lower ratio than forward, meaning the engine goes round more times than in forward to 1 rotation of the prop.
My guess is that 1 or more of the blades is getting to the "flat" position ie fore&aft and jamming there.
I've had it once, on my feathering prop - that was in forward gear - and cleared it by repeated application of forward and reverse whilst moored.
My assumption was that it was due to fouling.
Fixed props are definitely less efficient and produce greater drag in reverse - this is not the case with self-feathering props, where the blades rotate through 180°.
I find the contention that Kiwi props "are coaser in reverse" to be lacking in credibility, but am willing to stand corrected if any objective evidence (say from the Kiwi site) can b°rodued.
Many possible reasons are given on the Kiwi site http://www.kiwiprops.co.nz/reversing.html although we still don't know whether it is a Kiwi or not. Interesting that they publish such a list: it would seem that there is a real problem in this area. Nothing similar on the Brunton's site!
Well, for a motor boat a fixed prob is just fine. Many of us who sail have, however, found a feathering prob to have significantly less drag, letting us sail faster.
