UK-WOOZY
Used boat yesterday after a years work since getting it last year. the boat has been rewired. we are using a Blue Sea relay switch kit for the above battery and the start battery. There is also a 50w panel connected directly via its dual battery regulator to each battery. Used the nasa depth, incastec speed log, b&g vulcan 7 and onboard icom vhf on the boat yesterday. before end of the day the vulcan was flickering and i realised it was struggling for power. the battery was at 8 volts when i tested with a multimeter, engine start at battery at 12v so i put the blue sea selector switch onto emergency both so i could run the nav lights too and fusion stereo. before using the boat yesterday the house battery was on just over 11v as i leave the bilge pump on standby which is on a separate circuit direct to the battery via a fuse. Im sure the battery should last a lot longer despite using all the electronics and not even the lights or water pressurisation or the chart tables gps or navtext. Im sure it should last longer especially with the solar panel trickle charging all the time. we had only ran the engine to get off the buoy and back on as it was a club race we took part in, but the boat i had before without inboard has a similar rated panel that kept two batteries at 13v all the time and run everything including tv for 2 days.
