djs
Hi
It’s a 2016 FP genset that has been difficult to start. The unit is out as I have other work to do on it and so I have the head off as part of investigating what I suspect is low compression. The valve clearances have wandered a bit by which I mean they lose there correct clearance really quickly.
The exhaust valve is sitting higher in the head when closed. It’s not flush like the inlet valve.
Is this normal? I’d suspect not. I did research on here and found a few reports of corroded exhaust valves leading to poor compression.
Any thoughts on this? I’m going to see if I can attach a photo. The valve in the foreground is the inlet valve, the smaller (it is indeed smaller not just further away ?) is the exhaust valve. It is 2.1mm below the head surface.
Dave
Dave
