Fairline Targa 28 - Sloppy Steering
Bravo24
New Member
26 Feb 2026
Good day Targa owners
I have a 1994 Targa 28 which is in very good condition despite its age. It does have an issue with sloppy steering which is particularly problematic when navigating the Caledonian Canal and its numerous locks at low speed. With power off the steering wheel can be moved through about 45 degrees. While underway the steering feels very loose and I constantly need to correct.
I would appreciate experience from Targa owners on what the likely problem is.
The boat has Volvo Penta AD31XD engines and Volvo Penta AD31 DP outdrives
Is it hydraulic or cable steering, if the former it could be wear in the cable or in helm steering box. If the latter it could be low on oil or has air in the system. If these are ok then check for wear in the steering arm linkage and tiebar between the two steering arms.
Thank you Spannerman. I have not yet determined whether the steering is hydraulic or cable. Now I know where and what to look at I can diagnose and fix it.
Have a good evening.
If its anything like a chums Princess 286 , its sounds like a single cable system, which over the years has worn and requires considerable amounts of effort to turn wheel with loads of play.
A quick look should determine which system you have, if it is cable a fairly straight forward job to replace.
At slow speeds lightweight sports boats with outdrives are notorious for lack of directional stability and sorting that steering should make a considerable improvement in handling and enjoyment of boat.
