Fairline electrics again
sorry for delay but was traveling back form Spain. Its a Squadron 60 and its the celling lights outside which are controlled by dimmer and switch, checked the wiring and looks ok nothing loose and I can turn it off from the panel inside the cupboard.
I tried turning off batteries but no good and the lighting switch will turn it off from the control panel but once its switched on the light goes back on and you cant switch it off.
You I believe ( like our 65) have the can bus type electrics which caused a lot of issues for us.
The dimmers are mounted in a cupboard As you enter on the right but I don't know how the dimmer and the can bus system interacts.
Both are made by energy solutions and you will find them helpful on the phone.
Hi
The bus operates the e-plex module, and that obviously works as you can turn off via the lightning button at the control panel. So it is the switch, or the dimmer if combined with a switch. On my 58 there's a changeover switch, one stern beside the passarelle panel and the other just after the patio door in the saloon.
Rgds
Helge
BTW: Could you post a picture from the dimmer? I am thinking of installing some, particularly for the LED strips inside. The original installed strips were scrap, I changed them and now it is a bit bright.
yes no problem but not back until 10 December and already have an issue with Energy Solutions which I will contact again.
The switch is next to a dimer and I think the dimmer module is then located in the celling somewhere so may need to get electrician in.
