Faded stripped Dyneema splices - safe?
lw395
16 May 2007
Dyneema has 'very good UV resistance'. Not UV proof.
The colour is sometimes mostly in a surface coating of the braid, splicing these braids re-arranges the strands and some of the coating gets buried.
The splice will also end up less smooth than the rest of the rope and collect dirt.
I wouldn't worry about it unless you are operating at much higher loads than is normal for dyneema on a cruising yacht. I.e. if the dyneema is smaller than the wire you might notionally use instead?
thinwater
12 Dec 2013
Deale, MD, USA
sail-delmarva.blogspot.com
Hopefully you have some idea of the safety factor you are using. Without that, ANYTHING is a guess.
Many people have studied Dyneema vs. time.
https://www.cruisingclub.org/pdfs/sas_lifelines.pdf
https://gallery.mailchimp.com/9d288...ages/e636011f-6b87-44a3-ad30-3354b02d4b89.png
I have had old Dyneema rigging break; it's all about time. I just bought the boat and it was on the to-do list. Fortunately it was non-critical to the mast staying up, but it sure went "pow." Keep track of when it was installed and accept that 5 years is about the limit, depending on the stress and how critical failure is.
