aidancoughlan
Hi all,
I've got a new Facnor SD100 to install. (And I am waiting on a rigger to make up a new forestay for the boat).
I need to tell him whether to fit
(a) eye-to-eye type connections on the forestay (ie. no bottlescrew, or 'turnbuckle' as I think it is called)
or (b) a rigging screw on the bottom of the forestay (so it can be adjusted)
I find the Facnor SD100 instructions a little confusing (lack of pictures, and I am not familiar with the rigging terminology), but it seems to suggest that the drum can connect to either type of fitting. In the case of an adjustable rigging screw, this seems to require 'Link plates' - paralell metal plates which attach to the drum and extend down to the deck stemhead fitting to raise the drum above the rigging screw.
My rigger claims ignorance of the Facnor, but suggests that it wont cope with a rigging screw. (he is probably a bit pissed I didnt buy it from him). The non-technical staff at the local Dublin Facnor distributor suggest that it will, and a very helpfull gentleman at Crusader suggests the same.
So my questions for the forum are:
(a) Has anybody got one of these or installed one - I would really appreciate any practical advice on the installation, and its capability to adapt to either an eye fitting or rigging screw.
(b) If it can handle both fittings, which one is preferrable ? Is adjusting the forestay important enough to insist on the rigging screw type? My boat is a 27ft cruising boat.
(c) The Crusader guy mentioned a common installation mistake which can leave the forestay without sufficient 'articulation', I failed to really understand what he meant - anybody aware of what this could be ?
hope I've explained this well enough...
regards,
Aidan.
regards,
Aidan.
