F33 Fuel Fillers and Tanks
DIW
22 Sep 2002
Shropshire & Deganwy
Can anyone advise please on which fuel filler and tank relates to which fuel gauge ? or how to establish which is which. I can't work it out at all !
PhilF
18 Jun 2001
In a state
the right hand filler is the starboard tank, and so is the right hand guage, or at least it was on mine, a 330, but I am told they are the same configuraton,
Philf
powerskipper
18 Sep 2003
Dorset/ Hampshire. south coast
when filling up leave ignitions on and you can see which is which.
if not sure then, start an engine and you confirm which is which as dials for that side will register /forums/images/graemlins/grin.gif
johndove
13 Feb 2005
London
Came across a F33, when the owner left one engine running charging the battaries and walked to the club house and have a pint, while there got called back by a very /forums/images/graemlins/shocked.gifcross harbour master as fuel was being pumped out into the river.
Turned out the return pipes were cross which ment that fuel was taken out of one tank and pumped into the other and with one engine runnning over flowed one tank while empting then other.
So on a F33 with 2 tanks one in front of other they can be connected in either way.
powerskipper
18 Sep 2003
All Sealines have a fuel transfer system, This allows you to run both engines of either tank, but normally running is each engine runs off its own tank, with the cross over valves closed, there is normally a diagram near the valves that shows you how to change things around if you need to.
Roy
16 Jan 2004
Me : Perth
aft filler is definitely for port tank and port guage = port tank. Everything else covered already.
Roy
16 Jan 2004
Me : Perth
Sorry!!!!!!!!! As Phil said.......forward filler (left) is for port tank and port guage.
