njthake
Active Member
Prolonging the life of lead/acid wet batteries (my batteries) has become an obsession. I buy good quality deep cycle batteries (Trojan then Rolls, now Trojan) and good quality (Victron) charger and set up the best I can for winter storage-Float charge with marina supply.
There is the weak link, marina supply! Especially in Greece. Whenever possible I ask friends to check my supply is ok and more often than not it’s tripped off, heavy rain usually the culprit.
Unrectified this leaves the best batteries helpless and after a month or two they lose their charge below the threshold where self damage starts. I have no solar panels.
In the old days ( I’m a bit long in the tooth) batteries were always supplied “dry” with no acid. The retailer added the acid when the battery was sold. I am not sure if that is still the case. The point here is that with no acid there was no sulphation/deterioration and the shelf life was infinite.
Question for the experts.
If I remove the acid from the batteries over the winter period can I relax in thinking that they will not deteriorate. I understand all the problems involved in removal, and that the cells and lead (which has become a sponge) may need a flush with distilled water to become clean, but is there any value in the program. The price of replacements makes me look long and hard at any alternatives.
