ferroboat
we have a very small repair to do that requires being filled by expoxy filler. The chandlery here in Northern Spain only had a choice of one which is made by Hempel, and consists of a 1L tin of expoxy filler 35250 and a 1L tin of expoxy filler base 35259. Both tins have ring pull openings with a plastic cover which I presume is to put on after the tin is open, a bit like you see on tins of cat food. The amount I need to use is not much, the damage is less than 1/2 a square inch. When I open the tins and reseal them with the plastic covers, will it keep for use at another time, or will the tins go off? I presume one tin is the filler and the other the hardener.
Thanks in anticipation.
