hillyarder
Since i launched tyhe boat I had been plagued with a too hot engine, water just dribbling out the exhaust and lots of 'soot' in the water. I thought it was the impellor but that was ok. i read on the forum that soot in the water was back pressure. i decided to look at the exhaust which is inch and half bsp threaeded pipe going onto a rubber pipe. i suppose i should have realised it was the exhaust as it was 40 years old. i took off the asbestos wrapping ! and most of the exhaust just fell to bits. the bit that didnt was almost completely blocked. i cannot believe the engine run at all but it did and quite well. i had a new pipe made up (cost 30 quid - the rubber pipe was twice as expensive). now the question is should i fit a muffler in the rubber pipe as the exhaust has no silencer. will a muffler cause any backpressure problems. the engine runs like a dream now. its a petter 12hp twin by the way. i have been told i need a water trap but the loop in the steel exhaust is way above the water line and it has been ok for 40 yrs. also is there a modern alternative to the asbestos wrapping which migfht leave the metal cooler to the touch.
sorry for going on a bit. thanks for any help.
