biscuit
The vertical distance between the injection point of my exhaust and the water level in the water lock is close to the minimum recommended, despite having an exhaust riser in place.
The antisyphon loop is as it should be.
Having had some experience of water ingress and expensive engine damage in a previous boat (bent con-rods), I want to have belt and braces security against this happening again.
I have a gate valve at the exhaust outlet, for use in extreme conditions, and am about to fit a Cetrek Check Valve (from ASAP supplies): a simple, but apparently effective exhaust non return valve.
The question is: what would be the most effective location: between the elbow and water lock, or well downstream of the water lock? I can see pros and cons to both.
I have also wondered about putting a flap valve on the exhaust pipe itself. These seem more popular on motor boats than yachts.
