Viscount
I noted from an earlier post the suggestion that exhaust brakes were to stop an engine flood in the event of rapid deceleration. I had mine refitted on the understanding that they stopped smoke / fumes being emitted whilst starting and on tickover. Perhaps it is both?
Anyway, mine have stopped working properly (2 x Volvo AD31) isofar as they switch in and out when the throttle is operated whilst the ignition is on and engines off but stay open when engines running which kind of defeats the purpose. Closer examination reveals that they operate on the behest of a microswitch which changes state when the throttle is operated - this in turn operates a relay which puts 12V on what I take to be a control wire going to the exhaust brake solenoid (this unit also has permanent +12v and -12v directly from the starter motor). The wiring diagram for the engine only shows 2 wires going to the solenoid - a -12v and the control wire from the relay - it seems therefore that what I have is either wrong or more up to date than the original equipment. Any advice / experience welcome.
