sebastiannr
Hi there,
I'm sure this subject has been done to death, but I'm struggling to find info to answer my question, so apologies for flogging a dead pig.
The boat is a 10.8m GRP sail boat, currently in the Med. I recently inherited the boat, so I'm not overly familiar with her systems (a lot more complicated than on my previous boat). There is one anode on the hull, two on the prop shaft (I put two on because they were half the size of the one I removed, and were the only ones available) and one on the end of the prop.
After 2 weeks back in the water, there was already considerable corrosion to the prop shaft anodes - perhaps 10-20% (none noticeable on the hull anode). I would guess that they will have to be replaced well within a year if the current rate of corrosion continues. I'm reading through Calder's bible so that I can test the system, but I don't have a silver/silver half cell to put in the water to test for stray currents. As far as I can tell, the underwater metal parts are isolated, not bonded (there is no strap bridging the flexible shaft coupling).
When connected to shore power, the galvanic isolator status monitor shows no DC or AC leakage faults.
Does this excessive anode corrosion indicate that there is a serious stray current in the electrical system?
Any advice would be much appreciated,
Seb.
Seb.
