Excel dinghies
Mikedefieslife
8 Aug 2016
On a boat
Just wondering who here has an Excel dinghy and how it's been holding up?
I bought one in July last year on the back of a decent review in one of the mags, and a good spec list.
Had mine just over a year now, only used for half of that (due to being a marina in winter), but ran into a few problems.
First issue was the air floor. This developed a leak around a seem that has continued to get larger. It was still in guarantee, but there's no stock so spares have to be shipped (yes shipped as in on one of those big steel things us cruisers try to avoid at sea) from China. Wait time is a good 10 weeks or more, still not got mine.
Secondly, an oar snapped in two whilst rowing. I first thought it was the plastic bracket covering, but it turns out the aluminium itself was badly corroded inside and snapped. Replaced it with a 4 year old from an old dinghy.
Third is UV resistance. You should of course alway keep your PVC dinghies covered up. That being said, no chaps type covers are available, and many have had PVC dinghies last a good few years or more in Med/Carib sunshine before they start leaking plasticiser and eventually become scrap.
The type of PVC and the protection applied to it help. Some are better than others. Mine started getting brown and sticky within a month of use in this spring.
Anyway, just sharing. The guy importing them is friendly and helpful, but presumably limited in what comes over from China and the quality control there.
I have a 2.3m lightweight job and I won't be buying another. It's next to impossible to row because when I lift the oar blades out of the water, the handles foul my knees. Also, the towing eyes tore - simply too flimsy. I had them replaced by ones from a Zodiac, which look as though they'll last into the next millennium.One good thing - it's light enough for a decrepit old fart to lug around.
Perhaps the quality has reduced over time - had mine for seven or eight years and has worked well. Inflatable floor still good; rowing is OK (mine is an SD200 and I have long legs) although the point about being close to knees can be an issue. Mine doesn't get heavy use, it's only for when away from my home mooring but I would consider another.
The rowing is actually not bad in mine compared to the old slatted floor dinghy I had. The Excel is the SD260. The pain in rowing is that the plastic eyes where the rope handles run through foul the oars. It's just a bit of bad design.
The floor issue with mine is probably a one off fault, though the included SUP pump pressure gauge is suspect.
The plasticiser now coming out is biggest concern. Didn't expect it to happen so soon.
Oh well. I've been wanting a Rib anyhow. ;)
got a 10 year ish old one SD 290 IIRC, holding up well, Excel badge got the UV pox but the rest is good and tough. Not the lightest but has weathered being treated farily badly over the last 10 years, including a year in the sun with the previous owner in the Med.
