Excel 230sl versus 3D 230 dinghy
I have an SD 230 excel. No complaints about the dinghy except perhaps its weight but then since I bought they have introduced a new line which weighs much the same as other inflatables. Excel themselves were a PITA to deal with when I had problems initially.
We bought a 3d250 a couple of seasons back because it was very light. No complaints yet. It folds away easily, seems reasonably made - not cheap though. There are better stronger tenders out there, but few that have the weight advantage vs strength and capacity of the 3D.
never heard of the 3d before, but given the weight of the excel that I have I would seriously look at a 3d. I cant believe that it will be as sturdy or long lasting but a bad back lifting an over heavy dinghy is a lot worse than having to replace a dinghy thats fallen to bits a bit early.
I have a 3d 230. It really is so light that it almost flies on board. I haven't tried lifting it onboard in a strong wind. It might turn into a kite!
The material is made in Germany so it is good quality.
Ordered one now so thank you��
Strangely, mine came with a user manual that bore no relationship to the dinghy. Apparently there isn't proper one but it's all very simple really. One tip - if you lift it onto your boat, remove the seat first as it can slide out. It also makes it lighter.
I've just drilled a small hole in the corner of my tender's seat so I can attach a lanyard for this very reason
