Ethernet splitter
voyager35
17 Sep 2011
Hi I am fitting a new B&G Halo radar to my boat this winter. They are wired with an ethernet connector which goes into the chart plotter. Unfortunately the plotter only has one port which is currently used to connect the two chart plotters together . So i will need a splitter to connect the three cables together. I can buy one from B&G for over £300, which seems excessive for what looks like a simple connection. There are lots of splitters/switches for sale for very little money, would these be suitable (it would be inside the boat so waterproofing shouldn't be a problem) or do i need the special connecter?
thanks
AngusMcDoon
20 Oct 2004
Up some Hebridean loch
I haven't tried for B&G stuff, but I've done exactly this for Raymarine kit that similarly has only a single ethernet (they call it Raynet) port on the back of their MFDs. You can get hubs very cheaply from ebay for only a few pounds but these are not easily mountable and usually need a mains to low voltage DC adapter to power them and the power plug is a normal barrel type which isn't appropriate for a boat. So instead I use this...
https://uk.farnell.com/brainboxes/s...-100mbps-din-rail/dp/2383213?st=5 port switch
It is an industrial ethernet switch. It has a proper power connector, can be bulkhead or DIN rail mounted and runs on 12 Volts.
AngusMcDoon
20 Oct 2004
Martin_J
19 Apr 2006
Portsmouth, UK
And finally on board with a few spare minutes, I just checked which ethernet switch I installed... It must have been five years ago and it's been powered up ever since.
TP-Link SF-1005D. I was too long ago to really remember, but I do recall opening up all the small ethernet switches I had lying around and checking their internal voltage regulators... The TP link one was happy for 20v or so .. Anyway, its been running off the boat battery for the past few years.
Strange.. mine says 9v on the back. The current spec says 5v.... I'll have to check the others in the spares box.
lustyd
27 Jul 2010
Also available is the Teltonika TSW110 which runs on boat power and not that fussy with voltage. TSW110 - L2 Unmanaged Switch | Teltonika Networks for about £50.
If you want to do it on the cheap you can do without a switch either with a hub or just connect the bare wires and it'll act like a hub without any extra boxes. It's not pretty but TCP/IP does cope with it just fine. I'll leave you to investigate the wiring for that setup but it will work just fine for 2 MFDs and a Radar. You can use a hub like this one, although that's 5V so will need a step down for voltage. https://www.amazon.co.uk/NETGEAR-Ethernet-Unmanaged-Internet-Splitter/dp/B07PYSNSDD/
If you want to add in a router or a Cerbo at any point go with the switch.
voyager35
17 Sep 2011
Wow thanks for such quick replies
The one sold by Farnell looks promising as it isn't voltage sensitive. I shouldn't have connector fitting problems as all the cables are premade
