carljbray
New Member
Hi All,
Please could you help;
does anyone have any experience of replacing the original Yamaha 8c 2 stroke in an Etap, with something more modern?
eg a modern DFI 2 stroke or a four stroke, or potentially even electric - if the cost is not too restrictive.
My 30 year old etap, which I've owned for 4 years, the engine is sadly looking like a write off - it's a 30 year old outboard, so has done pretty well
I was hoping to get a couple more years out of it, but was aware it would need replacing sometime
There are a few issues which I can see with this straight from the start
- replacing a 2 stroke with a 4 stroke of similar power, will mean a much bigger and heavier engine, it will need to fit into a well on the etap, so size is an issue
- the fitting in the etap is not standard - it doesn't have the clamps you see on a standard outboard, or an obvious place to fit an engine with clamps - on the etap, there are two vertical screws, with a fitting on the engine that slots on top, with thumb screws securing it in place
- The fitting could probably be transferred to a "new" outboard, however there is also a heavy duty rubber Gasket/baffle which fit's snuggly around the leg of the engine, and into the well, which not only helps to stop water sloshing up the well, but would appear to take the majority of the force from the drive of the engine, rather than into the transom, like on a normal outboard
Has anyone been through this process, or know the best way around these issues?
Many thanks for any help,
Carl
Carl
