AndrewJ
I'm thinking of purchasing an espar diesel heater and installing the unit in a
locker in the cockpit. questions are: what is the operating temp of the unit. will I have to enclose the unit itself in an insulated box to keep from cooking my fiberglass. The present ducting I have on the boat is a combination of PVC piping (4 inch) and some stuff that looks like clothes dryer hose (aluminum foil with wire reinforcing spirals). will this take the heat output of the espar or must I replace this ducting. (this ducting is for a reverse cycle ac (16500 BTU)). I would like to run the exhaust of the espar out the existing exhaust pipe from the diesel engine with the use of a "Y" valve, would there a problem with the cooling water (it's a wet exhaust) backing up into the espar heater (the espar would be physically higher than the exhaust pipe). Any comments would be appreciated.. thank you.
<hr width=100% size=1>The only easy day was yesterday
